The Web View card allows businesses to display websites (HTML), such as a company website, news portal, or even a blog, where updates can be made easily, or from sources that are readily available online.
The Web View card is an Appspace supported card, which is officially created and periodically updated by Appspace with new templates and features.
Visit our Appspace Card Gallery to find the perfect card to deliver your message.
Apart from the basic card customizations, the following customizations are available for the Web View card:
- Website scaling options:
- Fit to screen – matches the web page display with the screen resolution and size.
- Custom size – displays the web page at a custom screen resolution and size.
- Custom size with crop – displays only a particular section of the web page.
This article provides the instructions to create and configure a Web View card, which allows you to embed an external website into the card with multiple embedding options, such as:
- Native Webview – displays the web page in the device’s browser without the ability to customize, as the web page is set as the source and is not embedded.
- XHR Proxy – uses XMLHttpRequest (XHR) proxy to by-pass some browser security settings, to display websites that do not allow embedding.
- Basic Authentication – allows web pages with basic authentication using the XHR proxy method.
NoteBasic Authentication has been disabled, and will not work for BrightSign devices running the 8.0 firmware and above.
- Iframe – uses the most basic way to embed web pages, and only works if the web page allows embedding. It may not work for websites that do not allow embedding, such as social media websites.
With the introduction of Content Categories in Appspace 8.0 ac.22, the Web View card template is assigned with the Productivity & Engagement content category.
This article provides instructions on how to create, configure, and customize the Web card to be displayed.
Prerequisite
- Ensure your device is compatible. Refer to the Supported Appspace Cards article.
- Account Owner, Publisher, Editor, or Content Producer (Author) role to add or edit content in Library.
Create and Configure Web View Card
The instructions below allow you to display Web content.
- To create this card, select one of the following options:
- Click Library from the ☰ Appspace menu, and select a library or folder you wish to create the content in. Click +CREATE, and select Card.
- To create and add the card directly to an existing channel, refer to Add Content to Playlist Channels.
- Select Feeds from the All Templates panel, and click Web View.
ImportantIf you are unable to locate the content, try using either the Search bar, the Order by, or Filter icon to narrow down the content that you are looking for.
- In the Edit tab:
- Enter the Title of the content as this will also act as the filename for the content. This is a mandatory field.
- Enter the website URL in the address field.
ImportantPlease ensure that the website URL or web content to be displayed is not within an iframe, as it is not supported, and will not be displayed in the card.
- Select one of the following Embed options:
- Native Webview – Displays the web page in the device’s browser without the ability to customize, as the web page is set as source and is not embedded.
- XHR Proxy – Uses XMLHttpRequest (XHR) proxy to by-pass some browser security settings, to display websites that do not allow embedding.
- Basic Authentication – Allows web pages with basic authentication using the XHR proxy method.
- Iframe – Uses the most basic way to embed web pages, and only works if the web page allows embedding. It may not work for websites that disallow embedding, such as social media web sites.
- Additional customization options are available when XHR Proxy, or Iframe is selected.
- Select Set website scaling to configure the following:
- Fit to screen – Allows the web page to be displayed to match the screen resolution.
- Custom size – Allows the web page to be displayed at a custom resolution.
- Custom size with crop – Allows a particular section of the web page to be displayed.
- Select More customization options to configure the following:
- Disable interactivity – Prevents users from clicking or scrolling the web page on devices with touchscreen or mouse attached.
- Display while loading – Displays the web page before it is fully loaded, with certain elements loaded after the web page is displayed.
- Customize the card background color, or image.
- In the Article tab: This section may be skipped.
- Include an Article or Caption to accompany the content item when being displayed on mobile apps, tablets, and other social collaboration apps.
- In the Schedule tab: This section may be skipped.
- You may add the content to a channel by selecting the channel from the Add to channel drop-down menu, or leave it unassigned to be added later.
- In the Settings tab: This section may be skipped.
- Once done, click SAVE.
Edit Web View Card
The instructions below show you how to edit a Web View card.
- Select and click the Web View card to edit, and select the desired tab to edit or view.
- In the Edit, Article, and Settings tabs:
- You may edit the content the same way as it was configured. For detailed instructions on how to do this, please refer to the Create and Configure Web View Card section above.
- In the Preview tab:
- In the Channels tab:
- In the Analytics tab:
