Web View Cards: Display Web Views with URLs
The Web View card allows customers to easily display websites (HTML), including your corporate website, a company blog page, or a news portal. Match the web page display with the screen resolution and size, display the web page at a custom resolution and size, or custom crop the page and display only a section of the web page.
    • Change colors, text, icons, and images to match corporate branding standards.
    • Customize the layout to suit your corporate message and tone.
    • Fully responsive, works on mobile devices, tablets, desktops, and digital signage.
  • Category Type: Feed
  • Content Category Type: Productivity & Engagement
  • Tags: Dynamic, Web
Please refer to our Introduction to Cards guide for an in-depth introduction to the types of cards that are ideal for your signage solutions.
Visit our Appspace Card Gallery to find the perfect card to deliver your message.
This article provides admins with instructions to create, configure, and customize the Web View card within the Library.
Prerequisite
Please refer to the Web View Card Release Notes for the latest updates, supported devices, and technical limitations.
Create and Configure Web View Card
Follow the instructions below to create and configure the Web View Card to display web content:
  2. Click Library from the ☰ Appspace menu, and click the + CREATE button.
    Alternative
    • Click +Quick Action from the Appspace menu bar on the top right, and select Create Card.
  3. Select Feed from the templates panel, and click the Web View card.
    If you are unable to locate the card, you may use the search bar, filters, or side panel to narrow down the content you’re looking for.
  4. Enter the Title of the card as this acts as the filename for the card content. This is a mandatory field and defaults to “Web View” if none is added.
  5. In the Edit tab section:
    • Enter the website URL in the address field.
      Please ensure the URL or web content to be displayed is not within an iframe, as it is not supported, and will not be displayed in the card.
    • Select the desired Embed options:
      • Native Webview (default) Displays web pages directly from the source on the device’s web browser.
        The background color will only be visible in editing mode and during device playback. In card preview and screenshot modes, the frameElement is inaccessible from the card, so the background will default to white.
      • XHR Proxy – Display web pages that do not allow embedding, by utilizing the XMLHttpRequest (XHR) proxy to bypass certain web browser security settings.
        • Proceed to configure the additional options.
      • Basic AuthenticationDisplay web pages requiring basic authentication.
        • Proceed to enter the Username and Password used to authenticate the web page.
      • Basic Authentication via XHR – Display web pages requiring basic authentication, by utilizing the XMLHttpRequest (XHR) proxy method.
          This option is not supported on BrightSign devices running BrightSignOS 8.0 and above.
      • Iframe – Displays web pages by utilizing basic embedding methods, thus may not work on websites such as social media sites that do not allow embedding.
    • Configure the following additional options when the XHR Proxy or Iframe embedding options are selected:
      • Determine the Set website scaling:
        • Fit to screen Screen resolution.
        • Custom size – Custom resolution.
          • Set the website resolution width and height (pixels)
        • Custom size with crop: crop a particular section of the web page to be displayed.
          • Set the crop region (left, top, width, height)
      • Configure the More customization options:
        • Disable interactivity Disables clicking or scrolling of the web page.
        • Display while loadingDisplays web pages before it is fully loaded, with certain elements loaded after the web page is displayed.
      • Set the background color, or image for the card.
  6. In the Article tab section: Optional.
    • Include an Article or Caption to accompany the content when displayed on the Employee App and other social collaboration apps.
    • Add a Referral Link to link more information to the content.
  7. In the Schedule tab: Optional.
  8. In the Settings tab: Optional.
    • The Name field will be auto-populated to match the Title of the content which will also act as the filename for the content. This is a mandatory field.
    • Select the Content Category from the drop-down menu to match the focus of the message, or leave it at the default content category.
    • Enter any relevant Tags for the content. (Optional)
    • Select a folder for the content in the Library Location drop-down menu to change the default folder location.
    • Select an expiry date for the content from the Auto Delete Content from Library drop-down menu. (Optional)
    • Upload an image to be used as the Thumbnail for the content.
  9. Once done, click SAVE.
Configure Refresh on Network Recovery
Improvements to the Web View card ensure that in the event of a network interruption, the website displayed on the Web View card will be refreshed once the device has regained network connectivity, rather than display a blank white screen.
In order for this feature to work, the admin has to configure the card’s manifest.json file and ensure that the following property, “ReloadsOnReconnect” has been set to true: (false by default)
"ReloadsOnReconnect": true
